Go Back   Forum Index > Shared Forums > Ask All Sailors
Ask All Sailors This forum is for owners of ALL sailboats. It's shared by Hunter, Catalina, Beneteau, MacGregor, O'Day, and other owners. For questions and comments specific to your brand of boat, please use the appropriate forum.
Closed Thread
Thread Tools Search this Thread
Old 03-25-2008, 04:21 am   #1  (permalink
sailortonyb Allied Mis
Allied Mistress 39 Ketch
Kemah,Tx.
sailortonyb Allied Mis's Avatar
sailortonyb Allied Mis hasn't generated any comments yet, may be new around here
Mast Boot
My mast boot is starting to crack from dry rot. I have never had one before so this is new to me. It appears to not have any seams so my best guess is that it was put on when the mast was pulled. Its a pretty big mast and I dont expect it to be a cheap job when the boat is hauled. Are there any alternatives, such as another boot to go over this one? Thanks in advance Tony B
sailortonyb Allied Mis is offline
Old 03-25-2008, 05:01 am   #2  (permalink
Joseph Shirley
Irwin Barefoot 37 CC Sloop
Port Orchard WA
Joseph Shirley's Avatar
Joseph Shirley hasn't generated any comments yet, may be new around here
Here is an answer I wrote for an earlier post
The mast boot can be made as a truncated cone from waterproof cloth such as Sumbrella with a double seam, or rubber such as from an old inner tube, or both; and slipped on before the mast is stepped. Failing that, since you have already stepped your mast you will have to use a wrap around boot with a folded seam in the back. The hardest thing to seal is the track extrusion that sometimes goes all the way down the mast. An extra sail slide with the bale removed that is caulked in place can help. A sealer between the boot and the mast with a large hose clamp around the boot at the mast is common. Tape over it after, to cover the screw part from catching anything. If you have a wood frame at the deck hole you can tack the bottom in place or use another clamp there. As for the mast partners wood or rubber wedges will work if they are not to severe. A more gradual wedge will drive tighter and stay in place longer. Since you have a ketch you probably don't play the backstay much, so you can block forward and aft also. If you play the backstay, the absence of fore and aft blocking allows the mast to bend more uniformly from the base. but can contribute to mast pumping (and possible failure), and loosening of the side blocking. Remember if you want to keep all the water out you have to seal inside the mast too, because water gets in at the many openings.. Generally that means that you have to drill a hole above the boot, and shoot some expandable urethane foam below the hole to completely seal the inside. Theoretically the water will flow down as far as the foam and drain out the hole.
Joseph Shirley is offline
Old 03-25-2008, 06:55 am   #3  (permalink
Nice N Easy
Seidelman S37
Slidell, La.
Nice N Easy's Avatar
Nice N Easy is well regarded
Just did this
Just replaced the one on the 37. The PO had made his own from an old inner tube, and hose clamped it in place. It did work, but looked like hell. I bought a new boot from Waste Marine. Made by SSI. It's white, comes in a couple of sizes, and while it does look better, it is overpriced, and certainly far from the ideal solution. While I don't think I want to pull the mast just for the boot, I am looking for something that works better than this one. Thinking of trying to make one from some of the very heavy plastic underlayment that is used on laminate wood flooring. It is gray and would look better than a piece of inner tube, and should work better than the 30 something dollar POS from Waste.
Nice N Easy is offline
Old 03-25-2008, 07:58 am   #4  (permalink
Taylor
Warwick Cardinal 46
Seattle, WA
Taylor's Avatar
Taylor hasn't generated any comments yet, may be new around here
Neoprene
I made my replacement out of neoprene. Head to a diving shop and buy a hunk of nylon backed neoprene in a color of your choice (blue and black are common) and some neoprene glue, which is a contact cement. Use two coats of the glue per the instructions. You can glue neoprene edge to edge and it will be both waterproof and strong. Its really pretty easy, and you this technique allows you to do it in the field with no more tools than a pair of scissors, glue and brush, screwdriver for the hose clamp and a tube of caulk. And newspaper to protect your deck. Takes about an hour. Joseph is correct about a truncated cone, it needs to be large enough go around the mast at the top, and around the mast collar flange at the bottom. The shape before gluing is a trapezoid with slightly curved top and bottom edges. Just cut and fit, cut and fit, and when you have it, coat with glue twice and pinch the ends together. The boot does not have to be a stretch fit, make it big enough so it goes around the mast with no tension and it will be easy to pinch the seam together. To make it look neater, have to top clamp put in place with the boot going up and then turn the boot down over the clamp. Then caulk with some clear silicone in the crack between the neoprene and the mast, filling any groves in the extrusion. If there is a little extra height in the boot, that's fine, it will roll up over the caulk and hide that too. I have a canvas cover with Velcro closure and ties top and bottom over my mast boot - it hides to neoprene (not that I think that matters) and protects the neoprene from UV. Variations include a patch of neoprene an inch wide over the seam for extra strength. It sticks better on the rubber side, so attach that with the boot inside out so it is inside when you are done, and the nylon side of the neoprene is out. You can also substitute wrapping 1/4" shock cord instead of using a hose clamp. Rather than tie shock cord, lie the two ends next to each other, hold them with a pair of pliers and stretch then and have a helper whip around them with seizing line. I prefer the hose clamp; easier to remove and replace. When I started kayaking, we made our own spay skirts using these techniques, and if they can stand whitewater rivers, they can seal a mast boot.
Taylor is offline
Old 03-25-2008, 09:55 am   #5  (permalink
Allan R
Catalina 36 MK II
Havre de Grace, MD
Allan R's Avatar
Allan R is a pretty decent person
Not Sure, But Try Looking At This:
I don't have any first hand knowledge, but they do offer an alternative for installation without pulling the mast. If you go with it, let us know how it works for you.
Allan R is offline
Old 03-25-2008, 09:51 pm   #6  (permalink
FrankR3878
Catalina 36 MK I
Mid Chesapeake
FrankR3878 hasn't generated any comments yet, may be new around here
Another way
Loosen all the stays and shrouds, climb to the top of the mast with the mast boot. Then the hardest part is streching it over the spreaders on the way down. HA HA - early April Fool Joke
FrankR3878 is offline
Old 03-26-2008, 12:04 am   #7  (permalink
John
Catalina 36mkII
Alameda CA
John hasn't generated any comments yet, may be new around here
filling mast
Joseph Shirly wrote: "Remember if you want to keep all the water out you have to seal inside the mast too, because water gets in at the many openings.. Generally that means that you have to drill a hole above the boot, and shoot some expandable urethane foam below the hole to completely seal the inside. Theoretically the water will flow down as far as the foam and drain out the hole." Have others done this? Do they agree? I ask because, with an in-mast furling main, I get a lot of water in the bilge whenever it rains.
John is offline
Old 03-26-2008, 12:55 am   #8  (permalink
Tim R.
Shopping For a new boat
Portland, Maine
Tim R.'s Avatar
Tim R. is a pretty decent person
This is what I use
http://www.ssicustomplastics.com/mastboot.htm Easy to install, watertight. I am not sure Neoprene is a good choice because it breaks down from UV.
Tim R. is offline
Old 05-25-2008, 05:10 pm   #9  (permalink
Michael
Guest
Posts: n/a
PERFECT!
SUPER!
Old 05-25-2008, 10:46 pm   #10  (permalink
RAD
ODay 32 centercockpit
Bay Shore, N.Y.
RAD's Avatar
RAD hasn't generated any comments yet, may be new around here
Tony
White silicone self fusing rigging tape is what I used 4 years ago and it looks and works great and this season I cleaned it up by adding more tape and to seal around the voids in the mast like the track and the little curves I used white boat life caulking. A couple of seasons ago in the middle of a heavy rain it statred to leak and I ran up there with my trusty ol roll of duct tape and like magic it worked then added more silicone tape when I got to port. some day I'm going to have pull the mast and cutting the tape and digging out cauking is going to be a job
RAD is online now
Old 05-25-2008, 10:50 pm   #11  (permalink
RAD
Bay Shore, N.Y.
RAD's Avatar
OBTW
Yesterday I used the same stuff and wrapped the GPS wiring coming out of the pedistal guard it looks great and also sealed it up from water getting in.
RAD is online now
Closed Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Visit our store at
SailboatOwners.com...
Store Search
15% off butcherblock stove top cutting board
Our butcher block stove top cover is a true work of art! Turn your stove top into useable counter.
Sunbrella boom tent sun awning
Protect your crew from sun and shade your companionway, too! Colors to match your boat\'s canvas.
Hatch and companionway screens
Turn your cabin into a no-fly zone with hatch and companionway screens. Highly rated!
Cockpit table with built-in wine glass holders
How is it that nobody thought of this 20 years ago?
Mainsail covers
Save now! Many pre-patterned for your boat... no measuring!
